Superhub 4 - Ethernet Issue
Just received a superhub 4 randomly from Virgin. I'm on the 50mb package.
Everything is good until I realised that there's an ethernet Issue. My android TV and power line refused to work whereas it was working perfectly fine with SH3.
It randomly refuses to work for whatever the reason
Tried resetting using the back pin. Different cables etc. Same issue
Any help would be much appreciated!
  • 3.82K
  • 175
  • 298
Re: Superhub 4 - Ethernet Issue
Good Afternoon Cption,
Thanks for your post on our Community Forums and very warm welcome to you!
Sorry to see you've been having connection issues with some of your devices connecting via Ethernet connection. Has this now been resolved or is this still on going? Do you have any devices that are connecting successfully over Ethernet connection or Wi-Fi?
Drop a response below and we'll look into this further if required
Kindest regards,
David_Bn
  • 14.29K
  • 591
  • 1.37K
...and their are some people on here thinking you can't get a hub 4 on lower package...
have you activated the hub 4?
You could ask to go back to the hub 3 or use it in modem mode and get a better router with 1Gb port or mesh and you be set for years.
I think* I have fixed it by removing the WiFi extender in the house. The problem with the TV was not just Ethernet but WiFi as well. It appears the WiFi extender and the TV were clashing somehow
Prefer the look of the superhub 3 though. SH4 is ugly..
