  • 12
Mellaggan
Message 1 of 10
Superhub 3 compatible wifi extender with ethernet port
I want to connect my CCTV DVR to my superhub 3, the 2 are currently on opposite ends of the house so I don't want to do this via LAN.
I've come across wifi extenders that have ethernet ports in them (like this - https://www.ebay.co.uk/itm/TP-Link-300-Mbps-Wall-Plug-Wi-Fi-Range-Extender-Boostear-Ethernet-Port/26...
Thank you
  • 12
Mellaggan
Message 2 of 10
Ethernet connection to wireless help
Reposting as Ive realised my original post was cut off:
I want to connect my CCTV DVR to my superhub 3, the 2 are currently on opposite ends of the house so I don't want to do this via ethernet.
Ive come across the attached:
Does anyone have experience of these kind of devices? If I understand it correctly I can connect my DVR to it via ethernet and then it will connect wirelessly to my superhub? obviously Im worried about compatibility issues with the superhub so if anyone can recommend something else Im open to suggestions.
  • 13.52K
  • 1.05K
  • 3.16K
Message 3 of 10
Re: Ethernet connection to wireless help
VM do their own wifi boosters as they call them - if you have a hub3 and use the app they provide it will look for dead spots and they may supply the boosters for free - think that depends on what package you are on - if they are not free they can be got for £3 a month or there abouts which is a poor deal imo
as to the one you link to - dont know it so cannot comment
____________________
Tony
  • 12
Mellaggan
Message 4 of 10
but does the booster have an ethernet port I can connect my DVR to? I thought they were just wifi boosters?
  • 1.89K
  • 105
  • 215
Message 5 of 10
We also supply Wired Boosters @Mellaggan 🙂
You can read more about our boosters here virg.in/boosterhelp
Cheers
Katie - Forum Team
  • 12
Mellaggan
Message 6 of 10
Thanks Katie, this looks like what I need. Do I need to buy them as a pair or can I just connect my DVR to one via ethernet and then it connect to the router wirelessly?
  • 1.89K
  • 105
  • 215
Message 7 of 10
They come as a pair - one pair will be one set 🙂
You plug one booster near your hub and connect with an Ethernet cable that comes with the kit. Once paired, you would then place the other booster elsewhere in your property. You then connect an Ethernet cable from the Booster to your device and your device will now be online.
Cheers
Katie - Forum Team
  • 12
Mellaggan
Message 8 of 10
fab, is there a link to where I can see a price and order them?
  • 10.69K
  • 1.09K
  • 1.71K
Message 9 of 10
Just check whether VM are going to charge you a monthly fee (£3/mo?) as if they are it might make more sense to buy your own (better!) ones - see...
https://www.techradar.com/uk/news/the-best-powerline-adaptors
  • 1.89K
  • 105
  • 215
Message 10 of 10
Hi there @Mellaggan
If you download our free connect app; you can go through our checks and see if you qualify for a free booster (dependent on your package).
They can then be ordered via the app. Our Wired starter kit would be £2 if you are not eligible for the free booster kit.
Cheers
Katie - Forum Team
