thegooner1983
Superhub 3.0 wifi
I'm having issues with 2.4ghz and 5ghz channels settings.
I save it to certain channels and then these settings change and won't save for some reason
I have to change these settings a few times in the last couple of weeks
Spoke to virgin technical, the only answer I got was there is a fault in the area and it will back up by 8
Don't think a fault on network would cause settings to change, think it's the hub that's the issue.
Is anyone else having or had this issue
  • 13.49K
  • 1.05K
  • 3.15K
Re: Superhub 3.0 wifi
would agree its not a fault in the area - offshore at its best that sounds like
have you turned off smart wifi - its in the wifi settings - not sure thats the problem but do that first - if that and all else fails post back and hopefully one of the VM people will get a new hub to you
____________________
Tony
  • 21.84K
  • 626
  • 3.67K
Sephiroth
"Smart WiFi" can cause channels to change in flight, so to speak. It is kept vague by VM as far as I can see (typical) but functionality is described at https://community.virginmedia.com/t5/Networking-and-WiFi/Smart-Wifi/m-p/3785946#M192602
So, as Tony says, turn that rubbish off. The hub will then revert to "normal" practice of selecting the least congested channels whenever it is rebooted/reset.
