on 20-03-2023 17:13
Hi there.
We have a superhub 2AC and after many years of working fine I now have a problem.
Whilst the wired link and the guest wifi network is working fine, neither the 2gHz or 5gHz main wifi networks are working.
I've rebooted it several times, and reset it as well, and the online checker says it can't check it.
Any ideas what else I can do?
Many thanks
on 20-03-2023 23:09
on 21-03-2023 07:25
John, thank you! I will do that and post here what happens.
Many thanks
on 23-03-2023 09:50
Hi there @jcgolding
I am so sorry that you have faced these issues regarding your Hub and connection and a big thank you to jbrennand for their help so far.
Have you been able to try their suggestion? If so how are things looking now?
on 28-03-2023 07:37
Thanks, John and Ash
i don’t understand it, but problem solved!
I went away for a couple of days (having changed various devices to my guest network), and got back home on Saturday, to discover the router had corrected itself!
So thank you for your help, and we’re back up and running!
best wishes
