ColinM9991
  • 10
Message 1 of 13
SuperHub 4 losing DHCP Public IP when in Modem mode with MikroTik
Hi folks,
Over the past 2 weeks I have been experiencing issues with my network connection whereby my MikroTik RB4011 is losing it's public IP address when connected to the SuperHub 4 that is running in Modem mode. This happens intermittently but often throughout the day and night, here is a screenshot of the logs from my MikroTik
This only started occurring within the past 2 weeks and I have done a full reset of all equipment (SH4, RB4011) in that time. I've also disabled my custom equipment and spent the weekend running on the SuperHub 4 but still experienced drop-offs.
My investigation over the past 2 weeks has been leading me to believe that the SuperHub 4, or there about, is the cause. I then came across this thread which perfectly describes my issue, all from the problem description to the equipment in use - everything is identical.
I thought I'd phone VM support today, to see if it was something that they could look at, but that was a mistake as the person on the other end just obsessed over WiFi and said the problem was that the SuperHub 4 was running on modem only mode which disables WiFi - talking out of their rear end, basically.
I'm hoping to get a bit more traction here so that I can actually work towards having this issue resolved. Has anybody here experienced this?
Here is my BQM which I have just set up today.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/674fce508d85fa53ec0388ff29814a7f43c1aa5f
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 13
Re: SuperHub 4 losing DHCP Public IP when in Modem mode with MikroTik
Ideally you'd need to rule out your own router.
Do you have a spare you could use to test? If not, leaving connected to a laptop could work to see if it does go down.
It may be worth posting up your logs:
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
ColinM9991
  • 10
Message 3 of 13
Thank you for your reply.
I have another router that is currently configured as an access point. This does also experience some drop-offs but I'm not sure if it's for the same reason.
My next few messages will contain the details from the SuperHub as requested.
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
ColinM9991
  • 10
Message 4 of 13
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
30
402750000
5.300003
40.946209
QAM256
30
1
138750000
6.900002
40.366287
QAM256
1
2
146750000
6.500000
40.946209
QAM256
2
3
154750000
6.300003
40.946209
QAM256
3
4
162750000
5.900002
40.366287
QAM256
4
5
170750000
5.400002
40.366287
QAM256
5
6
178750000
5.300003
40.946209
QAM256
6
7
186750000
4.900002
40.366287
QAM256
7
8
194750000
4.599998
40.946209
QAM256
8
9
202750000
3.799999
40.366287
QAM256
9
10
210750000
3.400002
40.366287
QAM256
10
11
218750000
3.599998
40.366287
QAM256
11
12
226750000
3.799999
40.366287
QAM256
12
13
234750000
4.199997
40.366287
QAM256
13
14
242750000
4.500000
40.366287
QAM256
14
15
250750000
4.699997
40.366287
QAM256
15
16
258750000
5.000000
40.366287
QAM256
16
17
266750000
5.000000
40.366287
QAM256
17
18
274750000
5.500000
40.366287
QAM256
18
19
282750000
5.400002
40.366287
QAM256
19
20
290750000
5.800003
40.366287
QAM256
20
21
298750000
5.800003
40.366287
QAM256
21
22
306750000
5.300003
40.366287
QAM256
22
23
314750000
4.699997
40.366287
QAM256
23
24
322750000
4.400002
40.946209
QAM256
24
25
330750000
4.300003
40.366287
QAM256
25
26
370750000
4.800003
40.366287
QAM256
26
27
378750000
4.900002
40.366287
QAM256
27
28
386750000
5.000000
40.366287
QAM256
28
29
394750000
5.099998
40.366287
QAM256
29
31
410750000
5.400002
40.366287
QAM256
31
ColinM9991
  • 10
Message 5 of 13
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
30
Locked
40.946209
1
0
1
Locked
40.366287
1
0
2
Locked
40.946209
3
0
3
Locked
40.946209
0
0
4
Locked
40.366287
0
0
5
Locked
40.366287
2
0
6
Locked
40.946209
1
0
7
Locked
40.366287
1
0
8
Locked
40.946209
1
0
9
Locked
40.366287
0
0
10
Locked
40.366287
3
0
11
Locked
40.366287
3
0
12
Locked
40.366287
0
0
13
Locked
40.366287
1
0
14
Locked
40.366287
0
0
15
Locked
40.366287
1
0
16
Locked
40.366287
0
0
17
Locked
40.366287
1
0
18
Locked
40.366287
0
0
19
Locked
40.366287
0
0
20
Locked
40.366287
4
0
21
Locked
40.366287
0
0
22
Locked
40.366287
0
0
23
Locked
40.366287
0
0
24
Locked
40.946209
0
0
25
Locked
40.366287
0
0
26
Locked
40.366287
0
0
27
Locked
40.366287
0
0
28
Locked
40.366287
2
0
29
Locked
40.366287
1
0
31
Locked
40.366287
1
0
ColinM9991
  • 10
Message 6 of 13
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
78
4K
1520
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
44
6.4
38068631
0
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
42.520599
5120 KSym/sec
64QAM
8
2
46200000
42.770599
5120 KSym/sec
64QAM
7
3
53700000
43.270599
5120 KSym/sec
64QAM
6
4
60300000
43.770599
5120 KSym/sec
64QAM
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
1
0
3
US_TYPE_STDMA
0
0
1
0
4
US_TYPE_STDMA
0
0
0
0
ColinM9991
  • 10
Message 7 of 13
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDH
SFID
8642
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
8641
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
ColinM9991
  • 10
Message 8 of 13
I've trimmed the older events from the network log as it was quite large. They're all DHCP events.
Tue May 25 11:15:43 2021
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun May 30 23:42:12 2021
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
6
DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon May 31 01:09:34 2021
6
CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon May 31 22:54:47 2021
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 1 09:58:15 2021
5
Tue Jun 1 12:09:56 2021
6
Fri Jun 4 04:50:07 2021
4
6
Sat Jun 5 00:10:22 2021
3
Mon Jun 7 08:46:10 2021
4
6
Thu Jun 10 01:09:26 2021
3
Thu Jun 10 20:46:10 2021
4
6
Sat Jun 12 10:53:45 2021
5
Mon Jun 14 10:34:36 2021
3
Tue Jun 15 16:59:39 2021
4
6
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 9 of 13
There are a couple of T3 timeouts that can cause D/S to drop (which would appear to be what is being experienced)
The power levels look fine with no errors.
I'm wondering if the ethernet port on the hub is borked.. or the cable! That could also give the same symptoms!
ColinM9991
  • 10
Message 10 of 13
I've just replaced the cable, with a backup that arrived this morning, and have plugged it into a different port on the hub. Will monitor the situation and see how it goes.
