  • 14
SuperHub 4 Lost speed on ONE ethernet port
I have an ethernet cable running from the Hub 4 to a switch in the loft that then delivers ethernet to all upstairs bedrooms.  The speed on all of these devices dropped overnight to under 100Mb for no reason.  I swapped out the switch but that made no difference.  Downstairs, all other directly ethernet connected devices were still getting 850Mb
I disconnected the cable going to the switch and plugged that directly into my laptop - 87Mb - thereby suggesting the port or cable.  I swapped cables round on the Hub and full 850Mb was restored to ALL devices.
I still can't work out why the hub was limiting one port until cables were swapped round...
Tags (2)
  • 24.55K
  • 1.41K
  • 3.12K
Re: SuperHub 4 Lost speed on ONE ethernet port
Because it’s a known (or little known) bug that sometimes the port speeds drop to 100Mbps on the Hub4.
