  • 5
Message 1 of 9
SuperHub 3 resetting constantly - Tech visit made things worse.
Hi All,
I have an issue which seems to be repeated several times across the forum, unfortunately these things get taken off-line once identified and we never see an outcome.
Basically my Superhub 3 (in modem mode) keeps dropping out, taking everything with it.
Earlier today it happened 3 times in 10 mins.
Its been going on for a week and a half. A Tech came out last Wednesday and although a nice enough chap he didn't fill me with much confidence. I told him id setup a broadband quality monitor via Think broadband and the figures looked bad with an entire red background denoting 100% packet loss - His response was that the BQM was not applicable for Virgin Media 🤣. Instantly lost a bit of credibility.
He looked at the SH and all the connections and was satisfied - He removed the attenuator from the SH and said "you 100% don't need that!" - He looked outside and declared that the splitter in the brown box had corroded (it looked fine) and it should have been changed long ago... So he did.
He came back in and showed me a handheld full of green bars and exclaimed that the issue was now sorted but he'd go and check at the green box in the street (sounds like flannel). My broadband speed had been OK, when it worked, prior to that... After that it was really sluggish struggling to get into the 30's (on a 100Mb connection). Its dropping all the time it's so frustrating!
The network log is full of Warnings and Criticals (see below)
I can't get hold of Virgin - despite an initial exchange on twitter the whole thing has now gone cold... I'm so close to walking away. I've been a customer since the Telewest days.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
5
38
256 qam
25
2
203000000
8
38
256 qam
9
3
211000000
7.8
38
256 qam
10
4
219000000
7.6
38
256 qam
11
5
227000000
7.3
38
256 qam
12
6
235000000
7.1
38
256 qam
13
7
243000000
7
38
256 qam
14
8
251000000
6.3
38
256 qam
15
9
259000000
6.5
38
256 qam
16
10
267000000
5.9
37
256 qam
17
11
275000000
6
38
256 qam
18
12
283000000
6
38
256 qam
19
13
291000000
5.8
37
256 qam
20
14
299000000
6
38
256 qam
21
15
307000000
5.6
37
256 qam
22
16
315000000
5.5
37
256 qam
23
17
323000000
5.4
38
256 qam
24
18
339000000
5
37
256 qam
26
19
347000000
4.9
37
256 qam
27
20
355000000
4.8
38
256 qam
28
21
363000000
5.5
38
256 qam
29
22
371000000
4.9
38
256 qam
30
23
379000000
5
37
256 qam
31
24
387000000
4.3
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
0
0
2
Locked
38.9
21
0
3
Locked
38.6
0
0
4
Locked
38.6
5
0
5
Locked
38.9
0
0
6
Locked
38.9
4
0
7
Locked
38.9
5
0
8
Locked
38.9
0
0
9
Locked
38.6
5
0
10
Locked
37.6
0
0
11
Locked
38.6
5
0
12
Locked
38.6
5
0
13
Locked
37.6
0
0
14
Locked
38.6
0
0
15
Locked
37.6
6
0
16
Locked
37.6
5
0
17
Locked
38.6
4
0
18
Locked
37.6
4
0
19
Locked
37.6
0
0
20
Locked
38.9
0
0
21
Locked
38.6
0
0
22
Locked
38.6
1
0
23
Locked
37.6
7
0
24
Locked
38.6
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400002
4.575
5120
64 qam
2
2
25800019
4.375
5120
64 qam
4
3
32599974
4.575
5120
64 qam
3
4
46199957
4.575
5120
64 qam
1
Primary Upstream Service Flow
SFID
617
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Time
Priority
Description
12/09/2020 15:42:10
Warning!
RCS Partial Service;CM-*;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 19:59:42
critical
No Ranging Response received - T3 time-out;CM-*-QOS=1.1;CM-VER=3.0;
09/09/2020 08:03:47
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-*CM-QOS=1.1;CM-VER=3.0;
09/09/2020 08:01:4
Warning!
Lost MDD Timeout;CM-*-QOS=1.1;CM-VER=3.0;
09/09/2020 08:01:0
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-*-QOS=1.1;CM-VER=3.0;
09/09/2020 08:01:0
Warning!
RCS Partial Service;CM-*-QOS=1.1;CM-VER=3.0;
09/09/2020 08:01:0
critical
09/09/2020 08:00:57
Warning!
09/09/2020 08:00:36
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-*-QOS=1.1;CM-VER=3.0;
09/09/2020 07:59:57
Warning!
09/09/2020 07:59:52
critical
09/09/2020 07:59:52
Warning!
09/09/2020 07:59:52
critical
SYNC Timing Synchronization failure - Loss of Sync;-*-QOS=1.1;CM-VER=3.0;
09/09/2020 07:59:48
Warning!
09/09/2020 07:54:14
Warning!
09/09/2020 07:54:10
critical
09/09/2020 07:54:10
Warning!
09/09/2020 07:54:10
critical
08/09/2020 21:05:37
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-*-QOS=1.1;CM-VER=3.0;
08/09/2020 21:05:36
critical
  • 6.7K
  • 502
  • 874
Legend
Message 2 of 9
Re: SuperHub 3 resetting constantly - Tech visit made things worse.
Your Hub stats look OK to me but the Network Log will need someone else to interpret.
Can you post a 'Live Link' to your BQM please ...
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 15.68K
  • 1.64K
  • 2.68K
Message 3 of 9
Do you still have the attenuator? Might be worth putting it back in and looking at the stats again as the down power levels, although still in spec, are towards the top of the spec (no lower than -6dBmV and no higher than 10dBmV - Close to 0 is optimal)
As Mike has said - seeing the (working) BQM would be useful for us and VM!
A wall of red can be caused by a few things. Firstly check that you current i.p.address (when you google for it) is the same as the one you have in the BQM settings. It can change - mine did it last week for the first time in years - or switching from modem to router mode will change it.
Also make sure the Hub is set to accept pings -- Advanced Settings > Advanced > Ping > Respond to ICMP echo requests sent to WAN IP (tick that box). Also there may be something similar in the Router settings.
  • 5
Message 4 of 9
No, the Tech took it with him.
I looked at the BQM and it had absolutely minimal detail on there, we're talking a couple of tiny green spikes, perhaps 3 in a 24 hour hour period and the rest was a sheet of red.
I deleted it and reset it up as i thought there may have been some issue in the way I initiated it, however the first bit of monitoring data is back in and it looks exactly the same.
The IP address was correct.
I changed the SH back into Router mode as there were no 'Ping' options in Modem mode.
Nor are there any options as you describe in router mode. This is what I've got!
Out of curiosity I put my Own IP address in the PING box and this was the result. Which also bears out what the BQM is telling me
PING **.**.**.** (**.**.**.**): 64 data bytes
--- **.**.**.** ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
  • 5
Message 5 of 9
Also just noticed on Think Broadband site that the BQM doesnt work with Dynamic IPs
Can you monitor my connection if I have a dynamic IP?
We can only monitor your line if you have a static IP address as we are not able to track changes to your IP address at the moment. We will look at adding this functionality in a future version.
  • 6.7K
  • 502
  • 874
Legend
Message 6 of 9
You have a 'sticky' IP address that is normally good for a few months.
Try the BQM again.
Mike Robinson
  • 15.68K
  • 1.64K
  • 2.68K
Message 7 of 9
My i.p. address changed a week or so ago for the first time in years and the BQM went red. I googled for my new i.p. address and altered the entry in the BQM settings and all is fine now. Note going to modem mode changes the i.p. too - going back to normal router mode changes it again but 99% of the time back to the one you had previously (if change in a short time-frame). So worth checking that.
Also worth checking whether your Hub (or router if you are using your own) has unticked the "allow pings" box - Navigate to routers web interface then in Advanced Settings > Advanced > Ping > tick the "Respond to ICMP echo requests sent to WAN IP" box.
  • 5
Message 8 of 9
Just had a hunt online as I couldn't find this feature anywhere.
I'm using Deco M4 Mesh system.... It doesn't have this as an option, according to what I've read.
  • 5
Message 9 of 9
This is pretty typical of what i was getting (albeit a very small sample)
