  • 26
Miss_NTL
Message 1 of 12
SuperHub 3: 2.4G speed and channels
What is the max speed of the 2.4G band of the Hub3? It reports 144.4Mbps. It should be 450Mbps. No?
I set the width to 20/40MHz. I only get one channel 6. I used to have two.6+10. Did imagine it?
  • 10.74K
  • 1.09K
  • 1.71K
Message 2 of 12
Re: SuperHub 3: 2.4G speed and channels
Depends on the receiving device - For example, my Macbook Air and iPhone7 both get 220mbps on my Vivid200 wifi connection - but only when I put them onto the 5GHz network. Sat in the same spot if I then flick them over to the 2.4GHz network, they max out at 70-80mbps - it's just the limitations of the technology!
  • 26
Miss_NTL
Message 3 of 12
What you are saying is correct but
Where is the second channel on 2.4G (as the width is 40Mhz)?
The max speed of the 2.4G band used to  be 450Mbps, why is it now 144.4?
The support guy told me that the new firmware disabled the second channel  and reduced the speed of the 2.4G band
I use acrylic and an android wifi analyser  for testing.
  • 314
  • 24
  • 64
sku11meister
Fibre optic
Message 4 of 12
basically the superhub3 is a pile of "toot". I would not bother using it for anything but in modem mode 🙂
** ++ Superhub 3 (Modem Mode) - Vivid500 - Unifi USG - Unifi Access Points - HP Procurve 24 managed switch - Netgear GS108 Switches - FTP and Plex Servers - NAS Drives ++ **
  • 10.74K
  • 1.09K
  • 1.71K
Message 5 of 12
The Hub3 broadcast on both frequency bands simultaneously - unless you have turned one or both off in the Hub settings.
However, out of the box, the SSID's of the 2 bands have the same name - hence you only see one "network" and it wont be obvious which frequency band your device is connecting too (unless its a 2.4 only device of course!) unless you have scanned and proven it.
I suspect when you were getting 450 it was connecting on the 5GHz band. Did you check that ?
You can always disable channel optimisation and rename the SSID's to split the 2 network bands so your devices see both bands separately and you can then select which one each device connects too.  And then of course you can optimise which "channel" each connects to on the 2 bands
  • 26
Miss_NTL
Message 6 of 12
I understand this
I have two scanners!...
I think the max speed was 450Mbps for 2.4G and 1300Mbps for 5G
Done that
Done this
I can do this.
And then of course you can optimise which "channel" each connects to on the 2 bands.
Indeed, I cad do this
I want to set up the second channel of the 2.4G band. There must be two channels, if the width is 40Mhz.
Note:I have all 4 channels in 5G operating simultaneously....
i cannot find the official full Hub 3 specs....Anyone?
  • 6.61K
  • 511
  • 1.1K
Legend
Message 7 of 12
You should never use 40 Mhz width on 2.4 GHz as this will normally cause a lot of interference for other uses and not necessarily increase your throughput. It is useless quoting theoretical speeds as nobody ever gets anything like the specified figures. I can get full speed on my 500/35 plan with the latest iPad Pro and very good quality Wireless Access Point, but then I’m only 2m away from the device.
  • 10.74K
  • 1.09K
  • 1.71K
Message 8 of 12
OK - see if someone else can help set you up. Meanwhile I assume you have seen this
https://community.virginmedia.com/t5/Networking-and-WiFi/Getting-a-better-Wireless-Network-Signal/td...
  • 26
Miss_NTL
Message 9 of 12
True but in my case I live in a country house, no neighbouring wfis, except several of mine. I can manage my own interference, I fully understand it, I am using spectrum analysers
True, but in my case, the other APs with 2 channels on 2.4G get ~300Mbps
True. But when the hub3 reports theoretical max speed 144.4 Mbps, you definitely can not get more than that. That's why I am looking for the missing  second channel on 2.4G.
Also true mate! But could I have my second 2.4G channel back? 🙂
  • 26
Miss_NTL
Message 10 of 12
Indeed. Thanks, splendid advice. I do exactly that for the rest of my APs, in order to manage interference.
