brianking1973
  • 25
Super hub 3 and TP link deco m5
I've purchased an M4 TP Link mesh WiFi with 3 Decos and put the SH3 in modem mode but the V6 box no longer can use any apps (e.g. YouTube, Netflix) with some error code displayed (I forget which one). It was connected to the SH3 using one of the ethernet ports which I'm assuming is now restricted to solely using the Deco. Can I put the V6 to connect to WiFi instead of using the ethernet cable or plug the ethernet cable from the V6 into the other spare ethernet port on the Deco?
  • 15.45K
  • 661
  • 1.51K
Re: Super hub 3 and TP link deco m5
@brianking1973 wrote:
...or plug the ethernet cable from the V6 into the other spare ethernet port on the Deco?
Yes thats what its their for if you need more ports you can get a switch.
