  • 6
Message 1 of 10
Super Hub 4 problems: Dead Spots, Slower speeds, Constant disconnections
So I was sent the Hub 4.0 without asking for it.
Installation was quick and easy but now I have constant wifi disconnections for my home CCTV. There are dead spots where there were none.
I've called Virgin for support over the last 3 days hour after hour each time to be disconnected after being on hold. The phone literally times out and I'm on hold now! So far today I have made 4 calls each lasting an hour with this being the 4th. None of which have been answered.
It's beyond a joke! I have my old router still and have tried to reconnect it but it doesn’t deliver any internet access.
I've had no issues with virgin over the last 2 years, its been ok. But this is silly and a service level no one should put up with.
Can anyone suggest how to get the Superhub 3.0 connected again?
Thanks in advance
Tags (1)
  • 24.47K
  • 1.4K
  • 3.11K
Message 2 of 10
Re: Super Hub 4 problems: Dead Spots, Slower speeds, Constant disconnections
Have you split the Wi-Fi bands? Chosen a less congested channel?
  • 6
Message 3 of 10
The whole point of the hub 4.0 is that it optimises the bands and does all of this for you.
  • 24.47K
  • 1.4K
  • 3.11K
Message 4 of 10
Not at all.
  • 6
Message 5 of 10
It's the whole ethos of virgin's USP mate > https://www.virginmedia.com/shop/broadband/intelligent-wifi
So.... yeahhhhh
  • 24.47K
  • 1.4K
  • 3.11K
Message 6 of 10
So.... yeahhhhh
And you believe it?
You need to split the Wi-Fi bands and choose the best channels to use yourself.
  • 6
Message 7 of 10
I don't understand why you'd reply with that, If it was untrue ofcom would have a field day. As would the rest of Virgin's customers.
Take a break, get some sunlight mate.
  • 24.47K
  • 1.4K
  • 3.11K
Message 8 of 10
So you can either do it, or put the hub into modem mode and attach your own router or mesh system.
Also the “Intelligent Wi-Fi” refers to the Hub3, as does the documentation, and 99% of people disable the “smart” Wi-Fi feature and let their devices do their own band-steering.
Hence it’s not included in the Hub4.
  • 6
Message 9 of 10
"99% of people disable the “smart” Wi-Fi feature and let their devices do their own band-steering."
... right
  • 24.47K
  • 1.4K
  • 3.11K
Message 10 of 10
... right
Yes. They do. Read the forums and you’ll see. The smart Wi-Fi causes more issues when enabled than when it’s off.
Which is probably a reason why it’s been removed from the Hub4.
