  • 4.65K
  • 369
  • 1.15K
Message 11 of 15
Re: Super Hub 4 No Modem Mode Available(1 Gbps Connection)
@jpeg1 wrote:
Without modem mode I wouldn't be here now. The inbuilt router is far too limited in function.
Ditto !   I hope VM UK don’t go down this route of no modem mode. I’ll be taking my custom elsewhere.
AJ95
  • 7
Message 12 of 15
@jpeg1: I agree the inbuilt router is far too limited.
@Adduxi: I totally agree, we need the continuing option of modem only mode.
@legacy1: You were correct, I called Virgin earlier today and they issued a request on their side to disable IPv6 for my connection. They asked me to turn the Hub 2.0 on and off after about 30 minutes after the call. No firmware was required.
I did this and upon logging into the Hub, Modem mode was now available. I enabled it and now my Asus RT-AX89X is working perfectly with it.
For clarity, the black Virgin "box" is known as the "Hub 2.0" but to you and I as the Super Hub 4 (SH4). This was the source of my initial confusion. Its the only modem offered for the 1 Gbps connection. Virgin also explained that to me today.
Issued resolved 😊
My only remaining concern is that, what happens when IPv6 is required and no longer optional? Those of us using Modem Only mode may be left with no options. I really hope this situation never develops. We who prefer modem mode only may need to unite in the future to express that opinion.
Thanks very much to everyone for their help.
  • 17.38K
  • 744
  • 1.75K
Message 13 of 15
No reason why we can't have are WAN IPv4 and IPv6 on a single MAC or have the hub be a router for IPv6 and pass IPv4 in modem mode they just want us to bend over and do NAT at the hub which we know can't support everything. Or they can do my real DMZ idea so the hub is a router for IPv4 does NAT but does DMZ your WAN IP to your device.
Many routers that do DDNS send the IP of the WAN interface which if NAT is done will not be the IP you want your DDNS to know.
jpeg1
  • 5.67K
  • 292
  • 964
Hero
Message 14 of 15
I don't think that would help at all.
The management of this company do not listen to their customers or even seem to recognise that we exist, beyond the income received from our monthly payments.
Even the internal communications within the company are appalling. Every day on here we see VM staff asking customers what progress has been made with a problem, instead of being able to advise the customer!  It must be just as frustrating for the staff as for us.
If O2 VM or whatever they call themselves at the time decide to abolish modem mode for any reason they will lose a large number of customers overnight.
  • 4.65K
  • 369
  • 1.15K
Message 15 of 15
Unfortunately most VM customers don't know or don't care about Modem mode and wouldn't know if it was switched off.  Yes, there will be many who will leave, myself included, to other ISP's, but I don't think it will hurt Liberty's bottom line too much.
Personally I love the Openreach approach of just supplying an ONT (basically fibre terminated in an ethernet port) into a property, and the users are free to pick whatever ISP they like, and depending on the ISP, their own Routers/Networking kit.
