login to the hub and change the SSID (network names) in the advanced settings so they are the same.
a factory reset may also do it...
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
