Message 1 of 7
Super Hub 3 ethernet and password not working
Hi- my Hub 3 ethernet ports have all stopped working. On top of this when I try to log into the hub using the 8 digit password it says password is incorrect. I have rest the hub via the pinhole with a pin and had the same 'password incorrect' error. Is anyone able to get this sorted?
  • 25.21K
  • 1.45K
  • 3.21K
Message 2 of 7
Re: Super Hub 3 ethernet and password not working
Do a 60 second pinhole reset
Message 3 of 7
Yeap as I said I have tried this reset and it has not sorted the problem.....
  • 12.3K
  • 952
  • 1.58K
Message 4 of 7
There will be nobody to contact tonight.
Try switching it off when you retire for the night and try again in the morning.
Mike Robinson
Message 5 of 7
Will do thanks.
Message 6 of 7
So 60 second reset has been tried but not worked and the ethernet ports are all not working- any ideas as to what has happened? Broken hub?
  • 25.21K
  • 1.45K
  • 3.21K
Message 7 of 7
Possibly. You’ll need to call up or use the sms service to request a new hub.
