Message 1 of 8
Super Hub 3.0 Connecting Cable
just received upgrade to Super Hub 3.0. No connecting cable in box, is it possible for you to send me a 1m one please?
David
  • 21.1K
  • 2.27K
  • 4.2K
Message 2 of 8
Re: Super Hub 3.0 Connecting Cable
What 1m cable are you after?
Upgrades to Hubs don't usually come with any new connection cabling (other than a power supply) as they're there to swap out an existing older Hub so all the same cables and connections can be used.
Message 3 of 8
Thanks Ben,
was going to take opportunity to move hub nearer to one (of three) of the sockets we have. Current cable is over 5m.
David
  • 21.1K
  • 2.27K
  • 4.2K
Message 4 of 8
Ah OK.
It's not usually something that's done often outside of the original installation as Virgin Media don't really want to encourage people messing with cabling more than is needed.
I'm not sure when the forum team get to this if it's something they can do.
  • 6.32K
  • 463
  • 1.09K
Hero
Message 5 of 8
You won't get a tech to come out for this, best to either just coil up the excess coaxial cable or run an extension electrical cable from the socket.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Message 6 of 8
Hi Roger,
thanks for the reply, not expecting a visit, thought it was worth asking if I could be sent a cable.
David
  • 6.32K
  • 463
  • 1.09K
Hero
Message 7 of 8
My belief is that VM might be able to send out 3m cables but anything different is done by a tech who knows how to properly terminate the ends with crimped F connectors.
Message 8 of 8
Hi Roger,
A 3m cable would be great if they could send me one.
David
