21-07-2023 22:30 - edited 21-07-2023 22:43
Is anyone please able to advise from the BQM and router data as follows what our issue might be/what can cause sudden problems like this, including booking a technician visit if it's needed?
Have had the same VM connection for around 8 years, no major issues apart from wide area issues. However around 6 weeks ago the connection became very unstable with constant dropouts etc, VM always said it looked fine on their end, they did send a technician at one point but they didn't seem to find much wrong, I think just tidied some wiring where it comes into the house, and advised about the WiFi Pods as separately we have always had bad WiFi in some areas due to concrete floors (we have since got one of the Pods thanks to one of the team members here). We went on holiday for a week and left the router turned off for that time, and after that it all seemed back to normal again. At that point I set up a BQM as advised here to keep an eye on it and it looked generally fine, occasional spikes but that's probably normal.
Then on Wednesday this week there seemed to be a sudden big problem shown on the BQM from 6 am for a few hours, and ever since then the connection has been very unstable and getting worse, constant dropouts etc:
Today (Friday) - tried rebooting the router around 2 pm which is what that red block is:
BQM link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f2b596e76b0c27b6470eb7bea09506538b992388
Online service status checker and the phone status checker both say no area issues. The online checker earlier today said it could see a connection issue (after running the tests, after the bit where it says there are no area issues) and to check back in 24 hours to be able to book a technician, then a bit later the 24 hours had counted down, but if I try it now it just says there are no issues and to try rebooting the router etc, so it doesn't now look like it's going to allow booking a visit tomorrow, but the BQM clearly shows there is still an issue!
Router data from tonight in next post, 8 hours or so after it was rebooted.
Thanks in advance for any help, really keen to get this sorted once and for all, can't keep having this happen every few weeks.
on 21-07-2023 22:31
1 | 330750000 | 4.6 | 40 | 256 qam | 25 |
2 | 202750000 | 6 | 40 | 256 qam | 9 |
3 | 210750000 | 5.9 | 40 | 256 qam | 10 |
4 | 218750000 | 5.9 | 40 | 256 qam | 11 |
5 | 226750000 | 5.8 | 40 | 256 qam | 12 |
6 | 234750000 | 5.6 | 40 | 256 qam | 13 |
7 | 242750000 | 5.5 | 40 | 256 qam | 14 |
8 | 250750000 | 5.5 | 40 | 256 qam | 15 |
9 | 258750000 | 5.4 | 40 | 256 qam | 16 |
10 | 266750000 | 5.3 | 40 | 256 qam | 17 |
11 | 274750000 | 5.3 | 40 | 256 qam | 18 |
12 | 282750000 | 5.4 | 40 | 256 qam | 19 |
13 | 290750000 | 5.3 | 40 | 256 qam | 20 |
14 | 298750000 | 5.4 | 40 | 256 qam | 21 |
15 | 306750000 | 5 | 40 | 256 qam | 22 |
16 | 314750000 | 4.9 | 40 | 256 qam | 23 |
17 | 322750000 | 4.9 | 40 | 256 qam | 24 |
18 | 338750000 | 4.8 | 40 | 256 qam | 26 |
19 | 346750000 | 4.5 | 40 | 256 qam | 27 |
20 | 354750000 | 4.3 | 40 | 256 qam | 28 |
21 | 362750000 | 4.1 | 40 | 256 qam | 29 |
22 | 370750000 | 4 | 40 | 256 qam | 30 |
23 | 378750000 | 3.7 | 40 | 256 qam | 31 |
24 | 386750000 | 3.2 | 40 | 256 qam | 32 |
1 | Locked | 40.9 | 95779 | 378525 |
2 | Locked | 40.9 | 134159 | 442081 |
3 | Locked | 40.9 | 130312 | 445023 |
4 | Locked | 40.3 | 125961 | 438416 |
5 | Locked | 40.3 | 124075 | 438274 |
6 | Locked | 40.9 | 121540 | 434379 |
7 | Locked | 40.9 | 118114 | 427760 |
8 | Locked | 40.9 | 114270 | 423489 |
9 | Locked | 40.3 | 110662 | 418578 |
10 | Locked | 40.3 | 109635 | 417536 |
11 | Locked | 40.3 | 107034 | 411689 |
12 | Locked | 40.9 | 104254 | 408109 |
13 | Locked | 40.3 | 102378 | 400065 |
14 | Locked | 40.3 | 101165 | 397818 |
15 | Locked | 40.9 | 99180 | 395952 |
16 | Locked | 40.3 | 97721 | 384509 |
17 | Locked | 40.9 | 95580 | 380624 |
18 | Locked | 40.9 | 93829 | 373019 |
19 | Locked | 40.9 | 90571 | 362437 |
20 | Locked | 40.9 | 89199 | 356813 |
21 | Locked | 40.9 | 88404 | 354571 |
22 | Locked | 40.3 | 88716 | 347474 |
23 | Locked | 40.3 | 87493 | 347158 |
24 | Locked | 40.9 | 85925 | 339330 |
1 | 49600000 | 38.3 | 5120 | 64 qam | 1 |
2 | 23600000 | 35.8 | 5120 | 64 qam | 5 |
3 | 30100000 | 36 | 5120 | 64 qam | 4 |
4 | 43100000 | 37.8 | 5120 | 64 qam | 2 |
5 | 36600000 | 37 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
5 | ATDMA | 0 | 0 | 1 | 0 |
on 21-07-2023 22:31
21/07/2023 21:00:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 21:00:27 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:55:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:55:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:53:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:53:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:44:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:43:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:38:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:38:10 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:37:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:37:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:36:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:36:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:34:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:34:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:33:54 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:33:54 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:33:52 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 20:33:52 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 22-07-2023 15:00
Have now managed to get a technician visit booked for Monday evening using the online service status checker (i.e. waiting for the 24 hour countdown from when first using it and it saying there seems to be a connection issue when testing the Hub). Would really appreciate some pointers as to what if anything from the above data is a problem and what might cause this problem to very suddenly start (and go away again seemingly by itself, if indeed it was the same problem that we had 6 weeks ago), will then have some more information to hopefully point them in the right direction on Monday.
on 22-07-2023 21:07
Well just had a message saying the technician visit has been cancelled because it's a "network problem affecting our area" - but the online and phone line status checkers still say no issues, which makes no sense. So still need help on booking a visit and getting an idea of what the issue is likely to be please.
on 25-07-2023 22:52
Connection seemed to go back to normal on Sunday 23 July, but would still like to know if this was an area fault that VM were aware of/resolved please, as if this has again "fixed itself" like it seemed to around 6 weeks ago then it is surely likely to happen again unless the root cause has actually been fixed by VM? At no point did the online or phone line service status checkers show any area faults.
on 27-07-2023 13:49
We're glad to hear that this seems to be working now. I have taken a look on our side and it looks as though there was a fault reported that has been resolved.
^Martin
on 28-07-2023 23:17
Ok thanks - hopefully it is properly fixed this time as have had this issue twice in 6 weeks or so, lasting a few days at a time each time
