pedwards13
Message 1 of 8
Sudden speed drop - RCS Partial Service...
HI all, new here so please be gentle!
HAd no problems with Virgin speeds for years. Sudden drop over last day which is affecting working from home, have posted stats below - can anyone please advise if you see an issue?
Many thanks,
21/04/2021 08:01:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 08:01:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 07:58:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 07:58:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 07:57:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1203000000-6.436256 qam9
2211000000-8.235256 qam10
3219000000-9.233256 qam11
4227000000-8.732256 qam12
5235000000-6.537256 qam13
6243000000-7.433256 qam14
7251000000-1034256 qam15
8259000000-10.534256 qam16
9267000000-8.535256 qam17
10275000000-6.736256 qam18
11283000000-836256 qam19
12291000000-9.736256 qam20
13299000000-9.236256 qam21
14307000000-7.536256 qam22
15315000000-6.536256 qam23
16323000000-7.436256 qam24
17331000000-8.436256 qam25
18339000000-8.237256 qam26
19347000000-6.937256 qam27
20355000000-6.438256 qam28
21363000000-7.737256 qam29
22371000000-8.737256 qam30
23379000000-8.737256 qam31
24387000000-7.537256 qam32
1Locked37.612717551153465
2Locked37.62683005228340
3Locked3544655671208547
4Locked34.745388972191377
5NotLocked36.825210471738480
6Locked3718637471041579
7Locked36.33467782201946
8Locked35.742033421704758
9Locked35.943780612854671
10Locked37.625663062517700
11Locked37.32341125676004
12Locked36.63240089918384
13Locked35.729847751769845
14Locked36.630832481645250
15Locked38.22358378724027
16Locked37.67910161102477
17Locked37.31250551632110
18Locked37.693145481236
19Locked37.654983480086
20Locked38.677775479188
21Locked37.6115154678882
22Locked37.31286274913265
23Locked37.31347091985895
24Locked37.6172606841748
16029987851512064 qam1
23940000050512016 qam4
35370000051512064 qam2
44620000049.8512064 qam3
1ATDMA0050
2ATDMA0040
3ATDMA0060
4ATDMA0070
Tags (1)
Andrew-G
  • 6.23K
  • 1.1K
  • 2.65K
Message 2 of 8
Re: Sudden speed drop - RCS Partial Service...
Your power levels have gone to pot.  Downstream's too low, upstream's too high.  This could be an area fault that will be resolved without a technician visiting your home, or it could be that they've fiddled in the cabinet and reconnected you to an unsuitable tap, in which case it'll require a technician to furkle in the cabinet, and visit you to confirm all power levels are back in range.  I'll flag for the staff to advise.
You can in theory check for faults by phoning or using an online checker, but neither seem accurate or consistent enough to point you in that direction.
pedwards13
Message 3 of 8
Thanks Andrew. Appreciate it. Do I need to do anything now, or just wait for the flagged staff to advise?
Many thanks,
Paul
Andrew-G
  • 6.23K
  • 1.1K
  • 2.65K
Message 4 of 8
Just wait on the staff is my advice.  If you're impatient you can try phoning it in, but phone waiting times aren't always good, and the quality of first line support is sometimes so poor that you wonder why they bother.
David_Bn
  • 4.98K
  • 229
  • 407
Message 5 of 8
Thanks for flagging this for us @Andrew-G
I've booked an engineer for you @pedward13
Please log into your self-care account to look into the time and date and if you need to re-arrange you can do via your account
Kindest regards,
David_Bn
pedwards13
Message 6 of 8
THanks, much appreciated
pedwards13
Message 7 of 8
Just wanted to say a big thankyou to @andrew-g and @david_Bn for their help. Engineer came and sorted wiring issue. Much appreciated
David_Bn
  • 4.98K
  • 229
  • 407
Message 8 of 8
Thanks very much @pedwards13, very kind of you to publicly acknowledge our efforts.
Pleased to hear this has now been resolved and if you have any further issues, you're always welcome to come back to our Community Forums
Kindest regards,
David_Bn
