NB1986
  • 9
Message 1 of 15
Streaming Issues
I have Hub 3 but not a V6 box and i am constantly getting issues when streaming across all streaming platforms iplayer, Netflix the quality is really bad and for example even watching a video on youtube it works for about 30 seconds then stops and takes forever to load again. This has been happening for a long time. I just don't have the time to wait on the phone to fix it can someone please help?
Niall
conman33158
  • 1.37K
  • 115
  • 253
Superfast
Message 2 of 15
Re: Streaming Issues
What package are you on?
Are you testing wired or wireless?
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Disconnect all other Ethernet cables when running the test
NB1986
  • 9
Message 3 of 15
Hi i am on
the speed results are
latency is 34.4
jitter is 6.74
download is 55.3
upload 8.89
conman33158
  • 1.37K
  • 115
  • 253
Superfast
Message 4 of 15
Wired or wireless?
NB1986
  • 9
Message 5 of 15
Hi this is tested by ethernet cable
conman33158
  • 1.37K
  • 115
  • 253
Superfast
Message 6 of 15
Can you please upload your router stats and set up a BQM
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
DO NOT LOG IN, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
NB1986
  • 9
Message 7 of 15
14190000004.138256 qam32
22030000007.940256 qam9
32110000007.940256 qam10
42190000007.340256 qam11
52270000007.440256 qam12
62350000007.140256 qam13
72430000007.340256 qam14
82510000006.940256 qam15
9259000000738256 qam16
NB1986
  • 9
Message 8 of 15
13260000035.5512064 qam13
23940000037512064 qam12
34620000037512064 qam11
45370000037.5512064 qam10
1ATDMA0030
2ATDMA0050
NB1986
  • 9
Message 9 of 15
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
,.iyewrkldJKDHSUBsgvca698
SFID26245
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID26244
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
NB1986
  • 9
Message 10 of 15
21/04/2021 09:04:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 10:58:2noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 10:58:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 11:49:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
