  • 7
Message 1 of 5
Still losing my broadband connection
I'm still losing my broadband connection even though we were told the fault would be fixed by 26th I'm in Bradford 5 area can anyone confirm there is still a fault as this has been intermittent for months.
  • 24.4K
  • 1.4K
  • 3.1K
Message 2 of 5
Re: Still losing my broadband connection
What is the service status page or 0800 number saying?
  • 11.49K
  • 891
  • 1.46K
Message 3 of 5
Let's try again ...
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 7
Message 4 of 5
Hi MikeRobbo,
I'm not the best on techy stuff but managed to get that monitor and here are the readings from 6pm last night, not sure what you can read from this picture but still losing broadband connection, although Virgin are saying the fault was fixed.
  • 11.49K
  • 891
  • 1.46K
Message 5 of 5
Then
Can you please
Mike Robinson
