Chalkie247
Message 1 of 8
Split Channels with Wifi Pod
I have just taken delivery of my new Wifi Pod as the coverage in my son’s room was non existent during peak times.
When checking the install instructions, I noticed that split channels should be removed however we cannot do this as then we can’t use our printer (it only works on 2.4ghz).
how can I work out which channel the wifi pod has auto connected to???
thank you.
stabilo00
  • 250
  • 32
  • 52
Superfast
Message 2 of 8
Re: Split Channels with Wifi Pod
You cannot use the pod and have channels split / named different. Printer should still connect just reset it to whate ever the combined channels are called.
-tony-
  • 16.54K
  • 1.31K
  • 3.91K
Message 3 of 8
spec says channels cannot be split but i tried mine like that and they seemed to work - i did not do extensive testing so it could give problems but if all else fails try it and see - you can always go back to both channels having the same ssid
____________________
Tony
  • 2.92K
  • 221
  • 624
Trouble shooter
Message 4 of 8
It could be the Pods will not be able to do band steering if the SSID is split? But that shouldn't be an issue in most cases.
Chalkie247
Message 5 of 8
Thanks Stabilo00, but unfortunately it doesn’t work. When router is set up on combined channels, setting up the network connection on the printer is impossible...it just continuously fails.
Chalkie247
Message 6 of 8
Does anyone know if the Wifi Pod will show as a device in Virgin Connect?? I see a device labelled with its MAC address...could that be the Pod do you think??? Or does anyone know how to find out the MAC address of the pod...i see only serial number on the actual device.
-tony-
  • 16.54K
  • 1.31K
  • 3.91K
Message 7 of 8
inSSIDer or similar will show the pods - i have 2 and when i go onto my hub it shows 6 mac addys so 4 are the pods - 2 for each band
Tony
Chalkie247
Message 8 of 8
Thanks -tony-, I’ll give that a try!! 😁
