Speed
Had engineer out fixed many problems but I pay for m200 which I get on 5g but only getting 50mgb on my 2.4 do I need to call and get engineer back
  • 24.97K
  • 1.44K
  • 3.18K
Re: Speed
No. That’s about right for the 2.4Ghz band.
Wireless speeds aren’t guaranteed or form part of your contract. Only wired speeds from compatible devices.
  • 12.12K
  • 942
  • 1.55K
Re: Speed
The problem with Wi-Fi speeds is the expected speeds far exceed realistic speeds.
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
