Message 1 of 7
Speed
Been in a week .
500mb modem only giving 28mb.
2nd modem the same .but now the phone isn't working through the modem .
Worked fine before the swap.
Levels are fine .
Loads of fec errors hitting the exchange at VM.
Disconnection department here I come . What a load of **bleep**tttg
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 7
Re: Speed
Virgin cable doesn’t use exchanges.
You need to speedtest with a wired device with a gigabit enabled card and a CAT5e or better cable.
Message 3 of 7
The my rg11 goes back to the fDP iniber node goes back through the ubr in the exchange ie thhe Re: Speed
The rg11at my house goes back to the dp in the street. Then back to the fibre node . Then back to the ubr in the exchange where TV/ cable modem / Telco . Are fed from .
So it does go back to the exchange .
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 7
Re: The my rg11 goes back to the fDP iniber node goes back through the ubr in the exchange ie thhe Re: S
No.
Again, virgins cable doesn’t use exchanges.
Anyway are these wired or wireless speeds you’re measuring?
  • 15.34K
  • 1.7K
  • 3.51K
Message 5 of 7
The correct term with cable systems is the Headend.
Exchanges relate to telephone based systems.
The termination is a CMTS, although there is currently still POTS infrastructure for the Landline phone service
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Message 6 of 7
Headend is where the Telco and TV and modem are distributed.
Modem via the cmts
They do go back to the exchange / headend . Same thing depending on bt or virgin.
Hard wired to the modem hub is 29mb . On a 500mb service with only the laptop connected. Ain't good
  • 20.96K
  • 1.13K
  • 2.7K
Message 7 of 7
Post the network, upstream and downstream logs
