on 25-07-2023 08:08
Just fitted hub 5 … speed tested on iPhone showing 800 mbps … i use deco mesh as signal not great through house .. as soon as I switch from hub to deco wifi it’s drops to 200 or lower ( all deco settings been done ) so speed tested router through Ethernet cable to laptop .. again 200 ish lower that my phone on wifi .. confused.com
Answered! Go to Answer
on 25-07-2023 08:31
With the Hub 5 in Router mode, what speed does the laptop achieve over a network cable to the Hub using the test below ?
Share the results please.
on 25-07-2023 08:31
on 25-07-2023 08:41
Hi Thku for your help .. SAMKNOWS showing 1153
on 25-07-2023 08:44
Speedtest by ookla ( that virgin said use ) nowhere near that .. using cat 8 cable
on 25-07-2023 08:47
on 25-07-2023 09:22
So speed at the Hub 5 ports and via the laptop are fine.
When you use the Deco Mesh ...
1) is the Hub in Router or Modem mode ?
2) is the Deco in Access Point or Router mode ?
3) Is the laptop speed test based on Hub 5 >> Cable to Deco >> Cable to Laptop ( i.e. No Wi-Fi /. mesh hops ) ?
4) does the Deco have QoS & if so it is fully Disabled ?
on 25-07-2023 10:12
I’ll go through this and revert .. Thku so much for your help
on 25-07-2023 10:29
Which Deco Mesh system?
When testing via Ethernet were you using a port on the node connected to the HUB 5, or a remote node?
on 25-07-2023 16:28
Ok so hub to deco deco to laptop .. speed test result … this is the main deco ( node ) hardwired …
on 25-07-2023 16:33
What make is the Deco Mesh? Hub 5 has Wifi 6 AX protocol, but the Deco may only have Wifi 5 AC protocol which is slower. Any 1Gb ethernet should top out at around 940 Mb in ideal conditions.
