  • 7
Message 1 of 12
Speed and devices?
hi team
I have around 15 -20 devices across phones, laptops, security cameras, robot vacuums etc. I am 100Mbps. I have a paired booster too
The connection drops out for 2-3 minutes during the day especially when more devices connect (e.g. kids come back from school or evening). Also i dont have enough reach in some parts of the house
Will the upgrade (recommended by Virgin) to 200mbps solve it? or should I consider more options like adding router modems
  • 11.61K
  • 899
  • 1.48K
Message 2 of 12
Re: Speed and devices?
I reckon a better router that can support more devices would be better than a pure speed increase although, a combination of the two would be better.
Think of it as mains water coming into your house and the fire brigade connect 10 hoses to the local water mains.
If they don't squirt water you can have a decent shower, if they start squirting the shower flow decreases, add a few more fire engines squirting water and your shower reduces to a dribble and the flow from each fire hose goes down as well.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 7
Message 3 of 12
How do I add a router - is this something Virgin can do for me?
  • 11.61K
  • 899
  • 1.48K
Message 4 of 12
You search out a router that does the job that you want and then buy it and fit it.
Mike Robinson
  • 17.3K
  • 1.82K
  • 3K
Message 5 of 12
Other options are getting a stand alone router and wireless access points or a Mesh system for easier set up.
In either case VM will not help - you will need to DIY - but with help on here of course 🙂
  • 7
Message 6 of 12
1 question
I understand I need to connect the 2 routers via cable . Thats a problem . There seems to be another access point in my house with a virgin white box & a cable wire coming out. Can I connect the router there ?
  • 17.3K
  • 1.82K
  • 3K
Message 7 of 12
The VM Hub should be able to be moved to the other VM white box (they are "usually" both active). Just unplug it, move it, reconnect it and try and see if it works ok. It may actually improve your wifi - or not?
Any additional router/wifi equipment needs connecting to the Hub (wherever you have it) by good quality ethernet cables.
  • 7
Message 8 of 12
Think am out of my depth here
I cannot move the hub because its connected to the TV via the cable
I can see if I can plug in the router to the second white box - though what I dont have is router which accepts a cable wire
  • 24.47K
  • 1.4K
  • 3.11K
Message 9 of 12
You would plug the hub into the white box on the wall.
  • 4.35K
  • 739
  • 1.77K
Message 10 of 12
Before spending any money on either faster speeds or new wifi kit, I'd suggest we take a look at your hub's status data and possibly setup a Broadband Quality  Monitor.  The usage you describe is normally within the capabilities of the Hub 3, and dropouts are not normally a broadband connection fault, not a lack of bandwidth ("speed").  If it a scummy connection, paying for a higher speed probably won't help, nor will spending any amount on a new router or mesh system.
Connect to the hub, click on "Check router status", and from the resulting window can you copy and paste in replies here the full contents of the three tabs titled Downstream, Upstream and Network log, as text not screenshots.  And mosey on over to Thinkbroadband.com and create a Broadband Quality Monitor, let it run for 24 hours and then post a link to shared live chart back here..
