jandickson
  • 12
Message 1 of 8
Sony TV connection
My Sony TV is suddenly saying it is connected to my WiFi but has no Internet connection. I have rebooted everything.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 2 of 8
Re: Sony TV connection
do other devices connect ok?
if everything else is connecting ok, can you reset the network settings on your TV? maybe a full factory reset..?
jandickson
  • 12
Message 3 of 8
Other devices are connected fine, although I have recently noticed my Samsung phone sometimes has the same problem. Turning wifi off and on sorts that, but it is annoying.
Tried the same on the TV but when reconnecting to wifi it still says no internet.
I have yet to try a factory reset as presumably I'd have to set everything up again on the TV ?
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 4 of 8
probably, yes.
you may find that there's an option to reset network settings, which would (obviously) just reset the network.. worth a poke around in the settings.
it's entirely possible that it's an issue with the hub rather than the tv, but as other devices are devices are able to connect it's probably worth starting with troubleshooting the tv first.
can you see what IP address the TV thinks it has when connected to the wireless network? if so, what is it?
jandickson
  • 12
Message 5 of 8
IP address is 192.168.0.23
Have tried Forget network and then refind.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 6 of 8
well, that's a good start - it seems to be getting a valid IP address at least.
it might be worth trying to configure DNS manually - set the DNS servers on the TV to 8.8.8.8 and 8.8.4.4 (googles dns servers)
jandickson
  • 12
Message 7 of 8
Will give that a go tomorrow ! Thanks
jandickson
  • 12
Message 8 of 8
Hi  - read in another thread that setting time/date correctly might sort it, so tried that - hooray, its worked !
