@vinodt1347 wrote:
With reg. to your message below
You might be better off buying your own router. Use hub in modem mode. It likely won't give any stronger signal (RSSI) but will be more stable and may give better throughput.
1. Can you recommend a router?
2. How do I put the hub in modem mode? And once I do that how do I connect the Hub3 unit to the new router? would that be via a ethernet port? Will I need to do further config on both the Hub3 and new router?.
Also, the help pages said not to change the auto channel management but you recommend some specific channels on 2.4G band. Iam not too technical - can you explain how I do all this?
1. I've found the D-Link routers good - but any reputable brand like TP Link, Asus, Netgear and so on - or one of the mesh systems with router capability.
2. There are instructions on these forums - once logged into the hub at 192.168.0.1 go to 'modem mode' and click on modem mode instead of router mode. Reboot hub. Boot own router, let it finish booting and plug into the hub (ethernet cable to first socket on hub - the one furthest from the power socket). VM hub should show red light (magneta). Can be tricky - I had to do this twice and reboot several times to get it to take.
You need to set up own router which should be straightforward. My D-Link 882 has a setup 'wizard' that goes through the main settings easily.
If hub is in modem mode you can still access the set up page at 192.168.100.1 to revert.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
