@Clairecoops wrote:
I've got the hub 3.
OK firstly, don’t panic or be too concerned, the red light on a Hub 3 is indeed a warning that it has become too hot; now it might be that, but it is far more likely that either the ‘world’s cheapest and shoddiest LED’ or another component (as used in the VM products), has failed and is giving a erroneous reading!
The dismissive fob-off from VM’s customer service provision is no more than we have come to expect, but even if this is a false-positive and can safely be ignored, if, in the future the hub ‘were’ to dangerously overheat, then how would you know?
So, no question about it, the hub absolutely needs to be replaced and I’m sure that in a day or two, a member of the forum team will get to this thread, offer to contact you via direct message to get details and arrange a tech visit to do just that.
