Solid red light superhub 3
Speckett2
Have seen many posts along the same theme as my own and hate reposting, tried calling virgin but was could not get through despite many repeated attempts, so here I am.. No loose cables, switched off countless times, reset via the reset on the rear of the router no effect, still red.. I have wireless and ethernet still, I have tried cooling it down with a fan, although this should not be an issue as it is in a well ventilated space and has been working fine for over 5 years. Like all things I guess, it has just reached its end of life.
It is being operatored in router mode, I have since gone into the settings to check if anything had changed ie:modem mode and no change.
It could just be a failed led, quite possibly this is the culprit, being that everything is working fine, however for the sake of it being a fire risk I would like to get it replaced, switched it off overnight as we always do and still the problem remains.
2 REPLIES 2
Speckett2
Update tp my prior well the router has been switched off all night so its definately cooled down if ever this was the issue, its not a cable connection issue as I have previously mentioned this has been checked thoughly, I did notice something however this morning which leads me to believe as I first suspected that it is the leds that are failing on the front panel. Through the space of 20mins they rotated through red|orange|white|red randomly if it was a psu issue then the router would more than likely be dropping out and it is operating fine. Both wireless and ethernet have no issues.
Ideally I would want to have it replaced, but not with the hub 4 as I have many friends and family that have experienced problems with this hub, althernatively i could just resolder a new led in place.
Hi @Speckett2
It more than likely from what you've said is a failing LED light (thanks for letting us know what you've done as well)
I'll send you a PM now to get a tech visit booked in.
Best wishes.
John_GS
