on 26-01-2023 23:32
Hi, I have a solid red light on my router. It's quite old, I think. Can you help?
on 29-01-2023 16:12
Hi Sparky1978,
Thanks for posting and welcome to our community 🙂
Sorry to see you're having some issues with the hub.
Can you confirm if you've rebooted and this is still the same?
Are you using the hub in modem mode?
Alex_Rm
on 29-01-2023 18:14
I have switched on and off, but not done a full reset. Is this by sticking a paperclip into the back?
on 30-01-2023 00:58
on 30-01-2023 12:45
It's Hub 3.0
As far as I know in normal mode. I haven't connected anything! Wifi is working fine, just there's a constant red light.
on 30-01-2023 17:45
Hey Sparky1978,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with the red light on your router and connection issues.
I would be happy to take a further look into this for you but first I would need to confirm a few details via private message, please look out for my message and we can get started.
Kind Regards,
Steven_L
on 30-01-2023 17:49
I had a similar issue.. from what I can tell something got unhappy after a powercut - not all devices could be seen on the app or homepage, or they'd show different devices, and then WiFi to one of the TV boxes kept dropping.. then the pods started disconnecting.
I got a new Hub3 installed today, nice white light, all appears stable for now, so definitely worth getting a technician in if you can get through
