on 07-03-2023 10:22
Have a solid red light on my hub 3 for the last two weeks and random drops in the wifi, have tried to test the hub several times to no joy. Any advice would be helpful on next steps.
on 07-03-2023 10:29
Hi Edwards2020,
Thanks for posting and welcome to our community 🙂
Sorry to hear you're having some issues with the hub. Can you confirm if the light is still red after a reboot?
And is the hub in modem mode or router mode?
Alex_Rm
on 15-03-2023 05:54
Yeah light is still red after rebooting the hib several times.
on 17-03-2023 09:16
Hi @Edwards2020 👋.
Thanks for your message of concern regarding your Hub3, may we ask if you completed these steps,
• Then use the power switch to turn the unit back on. The Hub should now operate normally
If the problem is still currently ongoing we may need to invite you for a private message in order to look deeper into this and resolve for you so that your Hub can be happy again 😊.
Please keep us updated.
Syd
on 17-03-2023 16:52
I have done what you have said and the hub still has a red light showing.
on 19-03-2023 17:39
Thanks for the reply @Edwards2020 on the forums. 🙂
I'm sorry to hear that this issue is still occurring.
I will investigate this further and assist.
I will send a private message - watch out for the purple envelope inviting you in to a private chat.
Kind regards,
Ilyas.
