Solid Red Light
Jfitzpatrick
Our Superhub 3.0 has been showing a constant solid Red light for months now. At first there were no connection issues so I just left it. However my wifi connections are very temperamental now and some things do not connect at all. Checked online forums and keep seeing that this may be an overheating issue which can affect performance. Hub feels a little warm to the touch but certainly not hot and it is not in Modem mode. I have rebooted the device and waited 24hrs, I've performed 20 sec reset button procedure and also an online reboot.
1 REPLY 1
Please do a pin-hole reset of your Hub3, they are not SuperHubs. If when the hub restart the LED is still red then the hub will need replacing.
