Only12months
  • 15
  • 6
Message 1 of 5
Smoking Wi-Fi booster and now dead
My VM power line Wi-fi booster suddenly decided to start smoking the other week, luckily I was home and it got disconnected from the mains before it caught fire.
I have since returned home and the booster is now dead, no lights (or smoke now!) so I presume it has died.
I have tried using the online chat bot a few times with no success as the bot decides that local engineering work is the reason why it has failed…..
can someone from VM get in touch to sort a replacement please?
it is a PG9072LG-VM unit.
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 2 of 5
Re: Smoking Wi-Fi booster and now dead
Same socket??
You may want to get it checked if it has killed 2 boosters...
Only12months
  • 15
  • 6
Message 3 of 5
Only had 1 device…not had any replacement !
Ayisha_B
  • 1.35K
  • 49
  • 132
Message 4 of 5
Hi @Only12months,
Welcome to our Community Forums and thanks for posting.
I am so sorry to hear this. I can certainly look into getting a replacement ordered for you.
Will pop you a PM now so we can clear security.
Ayisha_B
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 5 of 5
I apologise - I was thinking of another person!
I also thought you'd had a replacement as you mentioned you'd plugged one back in - I hadn't computed that you'd plugged a previously smoking booster back in!
