21-06-2023 20:53 - edited 21-06-2023 20:55
hello, I have my router in my lounge, I have a Panasonic tv which has an Amazon fire stick connected. when I first got Virgin WiFi it connected fine, however, now all it says is “no internet connection” when trying to connect to the TV, a tv in a different room, and my phone connects just fine.
I can connect the tv not working to my hotspot and it works fine.
Any ideas what has happened? It worked fine before, I’ve rebooted the router and still the same
on 21-06-2023 21:53
Ever used WiFi Pausing in the VM Connect app ?
on 22-06-2023 10:51
Hey @Sophiesherwin12,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you are having this problem connecting your TV to you WiFi, as @Client62, if you have ever used the Connect app you might have paused the connection to your TV, if you don't know how to check this I can happily direct you as to how.
Can you also confirm for me, does any error show on the TV when you try to connect, and are you able to find the right network on the TV?
Cheers. Joe
on 22-06-2023 15:15
It could be what Client64 is saying above if you use the VM Connect app . But from experience in the past with two Samsung tvs I've had it could also be the WiFi board inside the TV has packed in . There's not much inside a TV . Just a main board a wifi board and 1 or 2 others . But yes 2 wifi boards went on mine in the past . That's probably why that TV may not work also.
on 24-06-2023 17:35
Hello, not paused on the app.
if i search the wifi section on the TV it picks up my wifi name and says “available” underneath it, if i click and connect via the wifi password, the “available” then turns to “no internet”
Which is very strange as my laptop, and smart TV in my bedroom connects ok.
and the TV in question connects to my phone hotspot with no issues, just seems to not want to work with the VM wifi
on 25-06-2023 10:33
Hi Sophiesherwin12
Check that the TV has the correct date and time, and change it if necessary as that often prevents insternet connections working.
Have you tried to connect using the WPS button?
