Psy1
  • 6
Message 1 of 11
Slow wifi
So i have a 100mbps plan and i did a speed test and i am only getting 40mbps speeds on my pc when i do the test on my phone im getting the normal 100mpbs
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
Message 2 of 11
Re: Slow wifi
is your PC connected on teh 2.4ghz band?
Psy1
  • 6
Message 3 of 11
Re: Slow wifi
I have a internet for both the 2.4ghz and 5ghz ive tried both both are getting about the same mbps
gary_dexter
  • 28.95K
  • 1.77K
  • 3.78K
Message 4 of 11
Re: Slow wifi
Then it’s a limitation of the Wifi card in your PC
Psy1
  • 6
Message 5 of 11
Re: Slow wifi
The only question i have for you is So a few weeks ago my wifi was actually going at 100mbps and nows it stuck at 40-50 mbps  do u have any reason that could be or is it still just the wifi card in my pc
gary_dexter
  • 28.95K
  • 1.77K
  • 3.78K
Message 6 of 11
Re: Slow wifi
If your phone is getting 100Mbps then the line/connection itself is fine.
It could be that the pc is now connecting it the 2.4Ghz band rather than the 5Ghz band.
Psy1
  • 6
Message 7 of 11
Re: Slow wifi
I wouldnt understand why that happens tho as my internet is kept to the 5ghz internet as much as it can be
gary_dexter
  • 28.95K
  • 1.77K
  • 3.78K
Message 8 of 11
Re: Slow wifi
Have you split/renamed the 2.4ghz and 5Ghz bands to differentiate between them and connect to them independently?
If not the device will choose which band to connect to by itself.
Psy1
  • 6
Message 9 of 11
Re: Slow wifi
When connecting to a wifi each wifi at the end of the name as a letter 2 or 5 I stick to the 5 one so i dont think it will connect to the 2.4 when that internet should be forced 5ghz
gary_dexter
  • 28.95K
  • 1.77K
  • 3.78K
Message 10 of 11
Re: Slow wifi
What distance is it from the hub?
5Ghz is faster but speed reduces greatly over distance.
