  • 52
Message 1 of 11
Slow speeds and disconnects on Gig1 connection - Area 31
Since the last Engineer visit (Oct 17th) following an outage that left me without a connection for 4 days, I've had a lot of issues with my Gig1 connection. These include:
1 - Slow speeds. Since my router was reset I no longer can use SamKnows Realspeed - I just get the following message
Your SamKnows enabled device is offline
Please check your SamKnows enabled device is turned on and connected to the internet.
If I try a speedtest on Ookla (even though I know I won't see Gig1 speeds) the first thing I notice is I have a Virgin Business IP address (which is odd) and my download speed is always <200mbps (Slow), upload speed is between 35 - 50Mbps. Download should be >700Mbps using Ookla, as it was before when I first installed Gig1. This happens even when I reboot the modem, etc.
2 - Disconnects - Strange again, but quite often, and usually about midnight my connection will drop out leaving me in the middle of a Netflix program or movie, and unable to continue watching. I usually reboot the router and it comes back 10 minutes later. Annoying since I am usually watching TV in bed that time.
If I check the Router log there's lots of T3 timeouts like this:
Thu 12/11/2020 04:22:033No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Please could somebody help? I'm unsure of what could be wrong, just that something is NOT like it was when Gig1 worked properly.
My Power levels seem within range, I'm unable to post in this message due to the character limit. I'll try in another message.
  • 52
Message 2 of 11
Re: Slow speeds and disconnects on Gig1 connection - Area 31
326590000005.09999840.366287QAM25632
336670000005.19999740.366287QAM25633
346750000005.69999740.366287QAM25634
356830000005.80000340.366287QAM25635
366910000005.90000240.366287QAM25636
376990000005.90000240.366287QAM25637
387070000006.00000040.366287QAM25638
397150000005.80000340.946209QAM25639
407230000006.00000040.946209QAM25640
104830000006.40000240.946209QAM25610
114910000006.30000340.366287QAM25611
124990000006.30000340.946209QAM25612
135070000006.19999740.366287QAM25613
145150000006.00000040.946209QAM25614
155230000006.09999840.946209QAM25615
165310000006.09999840.366287QAM25616
175390000006.30000340.366287QAM25617
185470000006.30000340.366287QAM25618
195550000006.50000040.366287QAM25619
205630000006.19999740.946209QAM25620
215710000006.00000040.946209QAM25621
225790000005.69999740.366287QAM25622
235870000005.19999740.366287QAM25623
245950000004.50000040.946209QAM25624
256030000003.90000238.983261QAM25625
266110000003.90000238.605377QAM25626
276190000004.19999738.983261QAM25627
286270000004.50000040.366287QAM25628
296350000004.80000340.366287QAM25629
306430000004.80000340.366287QAM25630
316510000004.90000240.366287QAM25631
3.0 Downstream channels
32Locked000
33Locked969118160
34Locked9798546100
35Locked3969738910
36Locked3996972530
37Locked985198690
38Locked966033730
39Locked952199630
40Locked564376040
10Locked567572100
11Locked2739143960
12Locked1251463820
13Locked553114820
14Locked547966020
15Locked545405020
16Locked353707620
17Locked369335610
18Locked375281400
19Locked3568005100
20Locked332444230
21Locked349702140
22Locked366039170
23Locked350377540
24Locked532074470
25Locked6006446150
26Locked611356590
27Locked580437770
28Locked5849893130
29Locked605158160
30Locked610768150
31Locked4187993780
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM2048728
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 7.023017541
0
  • 52
Message 3 of 11
3.0 Upstream channels
14620000044.0205995120 KSym/sec64QAM3
22580000043.7705995120 KSym/sec64QAM6
33260000043.7705995120 KSym/sec64QAM5
43940000044.2705995120 KSym/sec8QAM4
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
  • 24.72K
  • 1.43K
  • 3.14K
Message 4 of 11
Why do you believe you have a business IP address?
  • 52
Message 5 of 11
It states "Virgin Media Business" on Speedtest. Of course, it may not be and I'm probably mistaken (Since it is a class C IP address), I just find that odd since it never stated this before.
  • 52
Message 6 of 11
PING ms 8
DOWNLOAD Mbps 228.30
UPLOAD Mbps 47.87
Connections Multi
Virgin Media Business 213.104.1xx.xxx (redacted for obvious reasons)
  • 24.72K
  • 1.43K
  • 3.14K
Message 7 of 11
What device are you speed testing with?
  • 3.64K
  • 282
  • 511
Superfast
Message 8 of 11
One of your upstream channels is out of spec:
  • 52
Message 9 of 11
Desktop PC wired to the router
  • 52
Message 10 of 11
Out of Spec? That's interesting. After the previous outage I had no connection, there was an issue with my upstream. The Engineer came, spoke to Network Services and informed me that due to the "noise" from my connection (I'm closest to the cabinet), there was a "block" put on my connection which they "unblocked". Apparently this is normal procedure, albeit most inconvenient for me. Would this have anything to do with this issue? How do I resolve this?
