@futureisvegan wrote:
Thanks for all the advice really useful to learn this stuff.
The Tenda Router I bought was "Tenda F3 300Mbps Wireless Router, Easy Setup, Parental Control, Bandwidth Control, Wi-Fi Schedule, with 3 External Antenna"
Isn't it a bit misleading that the product says 300Mbps but it won't do higher than 60mbs?
That's the theoretical wifi speed between two wifi points, in the real world about 150. However the ethernet ports on that unit are only 100Mb. It's all sales jargon. If you are only needing an access point, that's all you need to buy. Absolutely no point in buying a decent ac router and setting it into AP mode.
