on 01-01-2023 05:11
I have had the virgin media m500 package for almost 2 weeks and has been ok but for the past couple days it has been awful. I have ran many speed tests averaging at about 40mbs which is absolutely terrible being the lowest speed offered in my package is 230mbs.
I have checked their app to see if there is anything wrong in my area however it says everything is fine. I have checked all the cables and even restarted the router a couple times this week but nothing fixes it.
I am wondering wether I have a bad router or maybe they’re just experiencing heavy loads at the moment.
on 01-01-2023 08:46
Establishing where speed is lost is important if there is a fault.
The link below attempts a speed test to the Hub and then a speed test to the device.
The speed to the Hub should reflect the VM subscription rate, the speed to device may be less if WiFi is involved.
on 01-01-2023 10:14
How are you doing these speed tests? What devices are you using? Wired or wireless?
What speed do you get wired to the hub with a modern laptop/PC?
Can you post the stats off the hub - seen on pages at 192.168.0.1 (no need to login)
on 03-01-2023 16:58
Hi Energymonster32, thanks for the message and welcome back to the forums.
I am sorry to hear that you are having issues with the connection speed.
Can you perform a speed test on speedtest.net via a wired connection and let us know the results?
Can you create a BQM here
Kind regards, Chris.
