Slow and intermittent broadband - sw11
Hi, I’m getting slow or intermittent broadband at least 3 times a week for past few weeks. Normally between 8-9 and mid afternoon.
I get zero response from the help chat. Other than switching providers, which I can’t do yet. Are there any suggestions for what I can do. I already have boosters etc so it must simply be the connection coming into the flat .
thanks
  • 12.12K
  • 942
  • 1.55K
Re: Slow and intermittent broadband - sw11
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
What is your connection like at the problem times using a direct connection with a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
