Hi all
I have been having slow upload speeds for about the last 1 month and it hasn't got any better. My VM Hub 3 is in modem mode as I use my own networking router/equipment. The download speed has been excellent and I haven't had any issues with it since getting VM well over a year ago at my new build property.
I had a look on the forum and I think a few others posted this last year and it related to bonded upstream channels. I checked my Hub status and found that there were 24 downstream bonded channels but only 1 upstream bonded channel - seeing some previous posts here, I think there should be 4? I have quite a few "No Ranging Response received - T3 time-out" errors too, maybe a couple per day - not sure if this is related
I'm on the M600 package and average around 650-670mbps and I used to get around 42mbps upload until a month or so ago. The max I can get now is around 24mbps with an average of about 19-20mbps. It's not causing significant issues, although it's nowhere near the speeds I was seeing up until about a month ago.
Can any one here have any suggestions on what to do? I can add some stats/logs from my Hub if need be.
