Pennant
  • 21
Slow Intermittent WiFi
Known fault on Network last Weekend scheduled fix on Monday 1st.
Very slow and intermittent drop off since all systems Hub 3 and boosters BT wholehome x4) set and r e-set several times.  Both wifi and hard wire are failing.  Still nothing  Home schooling and working impossible relying on mobile hot spots.  £65 for 6Mbps.  All was well untill last weeks fault. tried e-mailing, phoning, message bots even Twitter no help to be had from anyone!!  C'mon VM you can do better than this?
  • 2.5K
  • 177
  • 511
Problem sorter
Re: Slow Intermittent WiFi
Post Network logs and all Power levels from the Hub. Also setup a BQM here www.thinkbroadband.com/ping
Pennant
  • 21
Where do I find Network and power logs?
Pennant
  • 21
