06-09-2022 09:22 - edited 06-09-2022 09:31
had 1 gig installed yesterday
getting 1128 mbps to the hub4 however only getting consistent 150 mbps through any Ethernet ports
New confirmed good cables are the same. Connects directly to the hub the same. Every device tested provides the same 150 mbs Ethernet connection
multiple notebooks tested and confirmed that peer to peer they received 1 gig Ethernet connection so this rules out windows and the cables. 150mbs on pc, Mac, Xbox (2 versions) and PlayStations. Cat 5e and cat6 cables tested
warm reset hub Hard reset hub. The same 150 mbs Ethernet connection. Don’t think it’s a cable issue because getting full speed to the hub so I’m thinking a potential hub problem
also I signed up for 1 gig. I believe I should have received a hub 5 as these are the standard with 1 gig connections from the 1st September
on 11-10-2023 23:00
Did you get a resolution to this, I have a similar issue with my Hub 4, I'm only on the M500 but getting less than 100Mb download on an Ethernet connection
11-10-2023 23:12 - edited 11-10-2023 23:13
Might be your ethernet NIC is 100Mb or bad cable
on 01-12-2023 10:26
Has anyone had a resolution to this, I'm on 500mb to the router but only getting 100mb on Ethernet
Tried multiple cables but all with same result.
Wifi output is fine
on 01-12-2023 10:47
I got a new hub and it’s been fine ever since. However the first engineer also tried one he had in his van and it made no difference. So I have no idea what the actual resolution was or whether the new hub was a coincidence or not
on 01-12-2023 11:21
I had a similar situation recently and I was persuaded that my hardware (processors? chipsets?) were the limiting factors. Now, I'm not so sure. Still no meaningful information here, as usual.
