06-09-2022 09:22 - edited 06-09-2022 09:31
had 1 gig installed yesterday
getting 1128 mbps to the hub4 however only getting consistent 150 mbps through any Ethernet ports
New confirmed good cables are the same. Connects directly to the hub the same. Every device tested provides the same 150 mbs Ethernet connection
multiple notebooks tested and confirmed that peer to peer they received 1 gig Ethernet connection so this rules out windows and the cables. 150mbs on pc, Mac, Xbox (2 versions) and PlayStations. Cat 5e and cat6 cables tested
warm reset hub Hard reset hub. The same 150 mbs Ethernet connection. Don’t think it’s a cable issue because getting full speed to the hub so I’m thinking a potential hub problem
also I signed up for 1 gig. I believe I should have received a hub 5 as these are the standard with 1 gig connections from the 1st September
on 06-09-2022 14:09
on 06-09-2022 14:14
@Eddie12341 wrote:getting 1128 mbps to the hub4 however only getting consistent 150 mbps through any Ethernet ports
The cake is a lie.😋
on 07-09-2022 10:25
So…..
brand new cat 6 cable
router set to modem mode
3 different devices tested one at a time on all 4 hub Ethernet ports max speed 170 mbs on all 4 devices
when I log into the router it tells me there are no Ethernet devices connected at any point
on 09-09-2022 11:11
Hey Eddie12341, thank you for reaching out and I am sorry you are having some issues with your connection.
I can see from outside you have a engineer due to come out to resolve this issues.
Please can you keep me updated on how this goes. Thanks
Matt - Forum Team
New around here?
09-09-2022 11:24 - edited 09-09-2022 11:32
Issue hasn’t been resolved
Because I’m getting full speed to the router the engineer said it was working fine however even when he did his speed tests on 3 different computers attached directly to the modem using Virgins own Ethernet cables the results were exactly the same - he couldn’t give me an answer why. Now while I agree his tests did show full speed to the hub it’s of no help when I’m only getting max 10% through Ethernet directly to the router
The fact that wifi is working fine isn’t much help
To be perfectly honest I’m not sure where to go from here. Obviously from the number of posts about this it seems there is an inerrant problem and yes some of these can be put down to windows however it doesn’t explain why non windows devices are the exact same
unfortunately he didn’t test another hub to rule they out. Apparently because it’s getting full speed to the hub then there isn’t a problem as far as he’s concerned but when you put the hub into modem mode. Remove every cable apart from one Ethernet cable to one Ethernet device and it still maxes out at 150 meg consistently then there is an issue somewhere and if it’s not a windows device then you can’t say it’s windows or cabling issue causing it. And strangely it’s every single device windows and Non windows even with virgins own cat 6 cables they all max out at pretty much the exact same speed. It’s almost like the hub is throttling the speed
on 09-09-2022 13:54
on 09-09-2022 16:33
These are brand new cat 6 Ethernet cables. I have even tested the Ethernet cable supplied by the engineer this morning but there is still no difference
hub in modem mode.
1 Ethernet surface pro connected to Ethernet port on the hub. Nothing else
and the results are below
on 09-09-2022 16:36
on 09-09-2022 16:37
I have even fully ruled out the Ethernet port on the laptop. These are Speedtest done through a usb 3 to gigabit Ethernet port adapter
