RoyKato
  • 8
Slow Broadband (both WiFi / LAN) - Many RS Errors
Good day all,
My broadband is suffering from heavy performance issues in the last 3 days, where I've seen slowdowns with both wired and wireless devices.
I have extracted the below Log, hoping this will give an hint of what's wrong (plenty of RS errors, unsure if this is the root cause):
vm dl status.pngVM Status checker states something different every time I run it, so I'd rather ask you experts.
I have performed the usual troubleshooting (rebooted the device earlier, checked cables).
Any other suggestions?
Thank you 🙂
-Rob
  • 1.74K
  • 109
  • 399
Super solver
Re: Slow Broadband (both WiFi / LAN) - Many RS Errors
Check for latest on local faults via 0800 561 0061 - it is a automated service.
RoyKato
  • 8
Thank you - I have called and seems no area issues are present.
It might be an issue with my device then?
  • 1.74K
  • 109
  • 399
Super solver
If your Hub is in Router mode it can be speed tested with :
Kain_W
  • 3.69K
  • 102
  • 263
Hi there RoyKato,
Thanks for your post and welcome back to the community.
Sorry to hear that you're facing problems with the service, just from checking our service I can see that you are currently affected by an SNR area fault.
The estimated fix time set for this currently is the 13th March at 13:10.
Our team will be working to resolve this matter as soon as they can.
Regards,
Kain
RoyKato
  • 8
Hi Kain
Thank you for your reply.
I will check by then and hopefully notice some positive differences.
Cheers!
