MATT31
Message 1 of 8
Sky mini
I have just recently moved broadband from sky to Virgin. I have SkyQ and everything has connected fine apart from the mini box in the bedroom. I can’t seem to get it connected, any Help would be appreciated.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 8
Re: Sky mini
How is it connecting?
Wireless or wired?
Does it need to be on a specific frequency band?
MATT31
Message 3 of 8
Re: Sky mini
It’s connected through WiFi.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 4 of 8
Re: Sky mini
Is there a way of factory resetting the Mini box?
Roger_Gooner
  • 6.74K
  • 490
  • 1.19K
Legend
Message 5 of 8
Re: Sky mini
My belief is that if connecting a Sky Q box to a non-Sky router such as VM's hub it's best to use the 2.4Ghz band (which means splitting the hub's bands into 2.4GHz and a 5GHz bands. Connect the Sky Q, factory reset the mini and connect it to the Sky Q box (done at 5GHz).
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
Gareth_L
  • 6.89K
  • 423
  • 778
Message 6 of 8
Re: Sky mini
Hi MATT31
How are you getting on with this
Did you manage to split the bands at all
If so has that fixed things for you
Gareth_L
MATT31
Message 7 of 8
Re: Sky mini
Thanks everybody for the Help,
I have managed to get it working. All I did was reset the min box. I was trying connect the signal from the actual mini box not the main box first🙈 Didn’t have to change any settings or anything.
Gareth_L
  • 6.89K
  • 423
  • 778
Message 8 of 8
Re: Sky mini
That's great news MATT31
Thanks for the update
Anything else, you know where to go
Enjoy the rest of the weekend
Gareth_L
