Jsquires1990
  • 165
  • 12
Dialled in
Message 1 of 24
Sky Glass and VM where to start with this...
Had Sky Glass since launch working perfectly on my VM BB connection.
The past few days I have noticed the Glass isn't showing images and app logos correctly and access to Peacock is restricted.
Sky say the service is fine, I believe them my dad has Glass (plus net) and Sister (BT) its all fine no issues to report.
What could cause these sorts of issues (way above my level of understanding) and who is responsible for correcting them?
Anonymous
Not applicable
Message 2 of 24
Re: Sky Glass and VM where to start with this...
I sense it is your device ie Sky Glass. Sky Help on Twitter suggest physically unplugging it for five minutes and then reconnecting again.
Roger_Gooner
  • 8.74K
  • 558
  • 1.66K
Message 3 of 24
Is the Sky Glass connected to the hub with an Ethernet cable? If not, do so.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Jsquires1990
  • 165
  • 12
Dialled in
Message 4 of 24
So have rebooted the hub and router then the tv!
Also, the hub is in modem connected to Nighthawk r7000 with ethernet to tv.
Im at a loss!
Roger_Gooner
  • 8.74K
  • 558
  • 1.66K
Message 5 of 24
I suggest a direct connection between the Sky Glass and hub to see if your problem disappears.
Jsquires1990
  • 165
  • 12
Dialled in
Message 6 of 24
Also I use primary DNS - 1.1.1.1 and secondary DNS - 8.8.8.8
Jsquires1990
  • 165
  • 12
Dialled in
Message 7 of 24
It doesn't!
Jsquires1990
  • 165
  • 12
Dialled in
Message 8 of 24
I think this is looking more likely to be a Sky issue than a network issue with VM
Roger_Gooner
  • 8.74K
  • 558
  • 1.66K
Message 9 of 24
An access problem to Peacock certainly looks like a problem for Sky to resolve.
Anonymous
Not applicable
Message 10 of 24
Doing a search on skyglass on Twitter points to loads of teething issues and instability. I also suggest approaching Sky Help. Good luck.
