  • 13
Message 1 of 11
Signal drop out
What is happening with my router and the loss of signal.
Over the last few weeks the signal keeps dropping out and the router goes through a re start process.
The last few days we have kept a log of when we have been in and noticed the drop of signal.
The times we have recorded the loss of signalk are as follows.
30/10/20  at least three times during day, times not noted.
31/10/20   15.22hrs & 18.45hrs
1/11/20   during evening (no time noted)
2/11/20   11.20hrs & 11.40hrs.
IO hope this issue can be resolved as soon as possible.
Thanks for help
Tags (1)
  • 12.27K
  • 950
  • 1.57K
Message 2 of 11
Re: Signal drop out
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 13
Message 3 of 11
Re: Signal drop out
I cannot find where to paste the link to the meter.
Any ideas?
  • 12.27K
  • 950
  • 1.57K
Message 4 of 11
Re: Signal drop out
You need to use Reply, not Quick Reply.
linkcamera
Mike Robinson
  • 13
Message 5 of 11
Re: Signal drop out
Downstream data
1402750000-0.738256 qam30
2202750000138256 qam9
3210750000138256 qam10
42187500000.738256 qam11
52267500000.738256 qam12
62347500000.738256 qam13
72427500000.538256 qam14
8250750000038256 qam15
9258750000038256 qam16
10266750000-0.238256 qam17
11274750000-0.538256 qam18
12282750000-0.738256 qam19
13290750000-0.938256 qam20
14298750000-0.738256 qam21
15306750000-0.938256 qam22
16314750000-138256 qam23
17322750000-138256 qam24
18330750000-0.738256 qam25
19370750000-0.538256 qam26
20378750000-0.738256 qam27
21386750000-138256 qam28
22394750000-0.738256 qam29
23410750000-0.538256 qam31
24418750000-0.938256 qam32
1Locked38.660
2Locked38.950
3Locked38.940
4Locked38.940
5Locked38.9180
6Locked38.6200
7Locked38.650
8Locked38.960
9Locked38.650
10Locked38.650
11Locked38.660
12Locked38.9140
13Locked38.6130
14Locked38.600
15Locked38.630
16Locked38.950
17Locked38.650
18Locked38.660
19Locked38.950
20Locked38.960
21Locked38.9120
22Locked38.950
23Locked38.990
24Locked38.950
  • 13
Message 6 of 11
Re: Signal drop out
Upstream data
13940000032.5512064 qam2
22580000033512064 qam4
33260000033.5512064 qam3
44620000033.5512064 qam1
1ATDMA0090
3ATDMA0010
4ATDMA0020
  • 13
Message 7 of 11
Re: Signal drop out
  • 13
Message 8 of 11
Re: Signal drop out
TimePriorityDescription02/11/2020 11:45:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:44:58Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:43:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:43:43Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:42:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:42:35Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:41:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:41:21Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:40:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:40:0Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:38:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:37:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:35:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:34:56criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:34:56criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:34:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:22:25noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:21:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:19:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/11/2020 11:17:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12.27K
  • 950
  • 1.57K
Message 9 of 11
Re: Signal drop out
Your Upstream Power Levels are too low.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 13
Message 10 of 11
Re: Signal drop out
Network LogTime Priority Description
