Settling in
Settings password for router not working
I have a hub 3.0 and my settings password is not working, i have tried turning it off and on again. I have also tried factory reset 3 times and I am still being told my password is incorrect. I am definitely using the settings password that is on the bottom of my hub. Is there anything else i can try.
I have tried getting help via message us, been through the bot security questions and told that they will connext me to someone who can help futher. I have been sat for over an hour now waiting and getting very frustrated.
Any help appreciated
  • 12.23K
  • 947
  • 1.57K
Re: Settings password for router not working
Do a factory reset on the Hub using this exact method  …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Hub-3-Password
Mike Robinson
