dariak
  • 8
Message 1 of 5
Setting up Yealink DECT IP Phone
Hi, I am a new VM customer and my package includes landline. My old landline phone wasn’t compatible with Hub 3 and I purchased a Yealink DECT IP Phone (W60B & W56H) hoping it will work with Virgin’s VOIP telephone system.
There are no proper instructions on how to set it up, it just says connect the base to the router via Etharnet cable supplied. Am I supposed to connect to VoIP telephone ports located at the top at the back of the hub? The Ethernet cable doesn’t fit in there, I can only connect to ports located underneath telephone ports. I’ve tried that but sadly it doesn’t work.
Can anyone please explain what am I doing wrong?
I’m sorry I’m not very technical as you can see from my message!
jb66
  • 12.16K
  • 899
  • 1.76K
Message 2 of 5
Re: Setting up Yealink DECT IP Phone
Virgin isn't compatible with IP phones, you use a regular phone. You should try and get a refund
  • 8.14K
  • 650
  • 1.42K
Message 3 of 5
What was the problem with your old phone, it should have been compatible?
goslow
  • 1.11K
  • 193
  • 353
Knows their stuff
Message 4 of 5
@dariak wrote:
<snip>
You need the small adapter lead (shown in bottom left photo here, which VM should have supplied you with)
https://www.virginmedia.com/help/home-phone-line-faults
and you just plug an ordinary phone into that
Robert_P
  • 2.57K
  • 129
  • 214
Message 5 of 5
Hello dariak,
Thanks for taking the time to post in regards to your new IP phone and the problems setting it up. We appreciate you raising this via the forums.
As advised by our members, IP phones are currently supported, we can see that you have called since your post and been transferred to our business team. Were they able to help with your query?
An alternative would be to use the adapter that came with the Hub to use a standard phone in the phone ports on the back of the Hub.
Rob
