richardesigner
Setting up NAS with an external hard drive via the Virgin Hub 3.0 router
Hi there. I'm wondering if it's possible to connect a USB hard drive to one of the Ethernet ports on the Virgin 3.0 router (via an adaptor cable?) so I can use it as NAS. I'm wanting to be able to connect to the hard drive via wi-fi on my iMac so I kind of have a home 'cloud'. Is this possible?
jem101
  • 4.82K
  • 482
  • 2.13K
Superstar
Re: Setting up NAS with an external hard drive via the Virgin Hub 3.0 router
Simple answer, alas no, this just isn't possible.
Roger_Gooner
  • 8.75K
  • 558
  • 1.66K
You can try something like the SSK 1TB Portable NAS Wireless Hard Drive.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
