  • 5
s21slm
Message 1 of 8
Set up wifi users
Does the Hub 3 have the ability to set up wifi user groups?
So the set up I used in the past with Disney circle I could pair all the Mac address for each device on my network to a user name, say child 1, child 2, guest etc.
So should child 1 misbehave I could turn off the wifi to all of there devices and it not effect anyone else.
It seems the Disney app doesn't work with Virgin so I would like a substitute.
  • 435
  • 18
  • 49
SonarUK
Fibre optic
Message 2 of 8
Re: Set up wifi users
Your looking for somthing with QoS / Parental Controls
D-Link DIR-882 Dual Band AC2600 MU-MIMO Wi-Fi Router RRP: 130 Discount £77.90
https://www.amazon.co.uk/dp/B075FZR9M4/
ASUS RT-AC86U Wi-Fi AC2900 RRP: £200 Discount: £179.91
https://www.amazon.co.uk/ASUS-RT-AC86U-AiProtection-Accelerator-Aggregation/dp/B075WFL15D
https://twitter.com/SeriousFamily
Vivid 350 | Hub 3 modem mode | Asus RT-AC86U (Stock-Firmware)
  • 4.34K
  • 499
  • 1.42K
Message 3 of 8
You can use the Virgin Media Connect app to pause Internet access on individual devices:
https://www.virginmedia.com/help/what-is-virgin-media-connect-app
A lot of the Netgear routers come with Disney Circle built in, if you would prefer to use that app:
https://www.netgear.com/landings/circle/
I believe the Netgear R7000 that I use has it but I have no kids so have never tried it.
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out.
My setup: V6 TV box, Vivid 200 Optical fibre with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Click to learn more about VIP
Use Kudos to say thanks
  • 1.11K
  • 50
  • 104
Moderator
Moderator
Message 4 of 8
Hi s21slm,
Thanks for your post.
Unfortunately, we aren't able to group devices together so you are able to turn certain devices off at the same time. However, as @SCA1972 has correctly mentioned, you are able to pause/unpause individual devices through our Connect app.
With regards to the Disney app, what happens when you try to connect to this through our network?
Lindsey_C
  • 5
s21slm
Message 5 of 8
Lyndsey_c
As the hub 3 is not a netgear device, Disney circle wont connect to my Hub 3.
Are they any plans to be able to group devices together?
Trying to remove a childs internet access 1 device at a time is a pain in the backside especially when they are not even listed alphabetically.
Cheers
  • 1.11K
  • 50
  • 104
Moderator
Moderator
Message 6 of 8
Hi s21slm,
We aren't aware of any plans to be able to group devices together, however, if this is something we bring in, in the future, we will be sure to let our customers know.
I'm sorry for any inconvenience caused by having to pause devices individually.
Lindsey_C
  • 10.07K
  • 1.05K
  • 1.6K
Message 7 of 8
As others have said, to do this properly requires you to get your own wireless router with that q.o.s/parental control feature or uses the Disney app.
  • 4.34K
  • 499
  • 1.42K
Message 8 of 8
@s21slm Do you still have the router you used the Disney Circle app with previously? If so you could try using that router with the Hub in modem mode.
Scott
