Message 1 of 9
Separate 2.4ghz & 5ghz on Hub 4
Is there a way to split the signals on the hub 4? I’ve gone in to all the settings but can’t see smart wifi like there was on the 3
  • 14.74K
  • 620
  • 1.42K
Message 2 of 9
Re: Separate 2.4ghz & 5ghz on Hub 4
If its not one thing its another...its like they started over with the hub 4 and didn't listen.
Message 3 of 9
Super frustrating as I can’t get my smart plugs to connect as they need a solely 2.4ghz connection.
  • 17.35K
  • 1.82K
  • 3.02K
Message 4 of 9
In the Hub3 it wasnt in "smart wifi" it was in Advanced>Wireless>Security, you just overtyped the SSID's and put in password(s) and saved/applied changes - is it not the same on the Hub4?
Message 5 of 9
Found it thank you.
Message 6 of 9
Please could you tell a 66yr old how to do this. Thanks in advance for any help
  • 24.65K
  • 1.42K
  • 3.14K
Message 7 of 9
As per the instructions above
Message 8 of 9
Thanks I'll give it another go tomorrow,
I couldn't find it in the hub 4
But like I say I'll have another go tomorrow
Message 9 of 9
Sorted, thank you
